Messerschmitt
I would like to expose a problem, with regard to single-acting cylinders with stem-side oil input.
more or less this is the problem: the cylinder is hung vertically, with the stem facing down and a weight attached to the stem. sending oil on the stem side, this falls back and raises the weight. instead the descent must take place quickly by gravity, putting to drain the stem side.
the position in which the cylinder is found for the most part of the time is the one with back stem and therefore with the raised weight.
to simplify the circuit, I thought to keep the room side dry and in communication with the atmosphere. in this way to bring down this weight I just need to unload the stem side, and the descent is not slowed by the fact that the cylinder must suck oil on the backside, with probable cavitation problems (the control unit is far and lower than the cylinder)
therefore remains the problem of caution against the accidental input of water or condensation inside the cylinder side back, which could give oxidation. for the truth the stem, for most of the time, is found returned inside the cylinder, so there would be no oxidation problems where the plunger flows, but I think it would be better to avoid just any oxidation.
what solutions could I take to not have water on the backside?
