Pack & go
  • Thread starter Thread starter GioC94
GioC94
Good morning
I have a pretty important problem in the pack & go function, and I don't know what and how to do.
I passed to a 2020 version of solid from a 2014.
I would and should take advantage of the pack & go function for a set, in order to make equal versions but with different names. Therefore I do not have to go up with suffixes or prefixes but I should use find/replace or still click 2 times in the first row of the table should open a window on which I can change a part of the codes.
Having this window doesn't open to me, even if I click on select/replace lower...I can't do this process for me fundamental and that gives me trouble.
Does anyone have the same problem and know how to solve it?
I don't understand, are there any 2020 versions that don't work well with the pack & go? (by hindering the fact that reading one of the messages to one of them works with the sp 2.0 version that is also mine, but to me it does not work).
Oh sorry, I didn't realize.
I solved with solidworks file utilities as you suggested. I opened the link you sent back to in your answer.
right click on the asm file (before opening it), solidworks entry, pack & go, and opens the same window that would open inside the software, unlike in this case select/replace it works perfectly.
Thanks again
