Yebisu
use of formulas to generate constant steps for fixing brackets so that they vary from height,
but with inventor 2017 I found this problem
value height 1458
initial offesett value 118
No ceil((((height - 75 mm ) / 2 on - offset_initial * 2 on ) / 350 mm) + 1 on result 30 instead should be 3 ten times to solve I did everything divided 10... but I still want to understand problem
I don't understand why you don't make the right calculation.
value height 1458
