DANI-3D
Bye-bye, everyone.
to make a project more truthful, and also for a good graphic presentation, and since some single carter will be painted with 2 or more different color areas, I need to color a sheet part and in particular a same surface with different colors, and here comes the problem, because, at least with wf5, I can't do it. when I happen the same problem with a particular not of sheet metal I create of the bottoms of a few cents, so that I am born of new surfaces, but with the sheets I can not do this.
Do you know any procedure or trick?
thanks to everyone in advance.
