andrea1974
Hello, in the ball together, I'm going manually, is there a system that tells me if I've got everything in the table? or if I forgot a few balls. .
go to the properties of the view and connect the view to the distinct correct materials. You usually don't need it. You can see you messed up the table.and so for all the others, it seems that it refers to another together... .
Great, now it works, I've reconnected to the same distinction that was already there before, but now once again we say it works... He's got a delay like saying...go to the properties of the view and connect the view to the distinct correct materials. You usually don't need it. You can see you messed up the table.
I'm waiting for your feedback
then the effective solution is only one: the company must be provided with a trusted assistance to use and to which, if necessary, the files can be sent. I'm sorry, but the problems you see seem impossible. The only thing that comes to my mind is that there are messing up with configurations. of the type that the table refers to one configuration and views to another, I do not find any other explanations.I realize, but I can't attach the file together... for privacy of the company.
the 4 screws and washers does not see them. only one in the table.
