pallination with underassieme weight: possible? how?
reggio
hi, it would be possible to get pallination with weight of Solutions, without doing it by hand as in my example? Eat?
if I use "weight" gives me the weight of the single touched part ..
In the past you had explained to me the trick of the point at the center of the subaxieme, touching the point of the subaxieme with the arrow of the ball in fact obtained the weight of the subaxieme, but, between model opening, put point, save, open table, look and strike prorio the point at the table, ... it was first done to make it by hand :(
try to insert the weight property to the bubble and then open the link window to the properties and select the weight property.... .1704817102111.webp
1704816907699.webpyou must enter data into the sub assemblies:1704816989477.webpIt doesn't give you the measuring unit even if you insert it into the description. or at least not to me:)
I tried again, to me from the weight of the subgroup, but does not put the unit of measurement.
thanks to both, but, to both I ask: that is the weight of the part (I don't care) or all underarms ? (I care)
of the subassembly, I inserted the weight data only in the subaxieme not in the individual parts if I open the subaxieme and create a design gives me the empty balls.. .
I solve by putting a note that all the measures are in kg...cmq also I am abruzzese, a small village near vast. but escaped in the north of the land I miss too much our sea:(
if you use the bubble with a distinct present in the drawing see the properties corresponding to the bubbled piece. If you want to see both the weight and the unit of measurement I recommend you create a custom property that combines the weight with the text "kg". recalling in the bubble this property gets both the value and the unit of measurement.
