pan command on the mouse wheel
  • Thread starter Thread starter franzarch
franzarch
hello to everyone I have a nice problem that I can't solve.
I bought a new mouse with cordless logitech deluxe 660 but architecture 2009 does not make me work the pan when I click on the wheel.
How do I activate it? ?
nb if I shake the active wheel zoom... until here everything okay, but if I click??? ? :confused:
if you have installed the mouse drivers, the logitech allows you to set the function of the wheel as well as of all other keys. You have to see between those options. I had the same problem with autocad.
that problem was created only with the installed drivers of the logitech, I remember that there were two options, one for the scrolling of the wheel (and in that case the scroll is fine) and one for its pressure. I don't remember, however, that settling died to make it work.
to set this system variable within architecture type mbuttonpan and to the request of the new value indicates 1.
already is set to 1.
But it doesn't give me the pan function by pressing the hammer... as I am going to the asylum!! ! !
but what is set in the mouse management software at the central key pressure? depends on that.
neither software of the logitech there is the option click rotellina, but there is slide set to universal scrol, sharp to right page, sx page wheel.
If you want to keep the logitech drivers you have to set the mouse wheel not as "universal scroll" but as "central button". alternatively uninstall the logitech software, so much the mouse keeps working smoothly.
I solved with autocad putting on the wheel the function "central button" as mv82 said and clicking on the settings to use the scroll only with office.
This way by clicking the wheel makes me the pan and scrolling it makes me zoom
I also carry my experience with logitech m310 mouse, but it is worth any kind of mouse.. .
I was getting crazy! I changed any setting, driver, autocad mbuttonpan variable on <1>.
Then I got a doubt!
I tried to crush the central key strong and how by magic appeared the pan!!! ! you've got the key! !
I'm ashamed as a dog, but maybe reading someone might waste less time than I!
I highly recommend to all to make a try with another mouse before scaraventing the mouse with all the pc from the stairs :biggrin: :biggrin:
