paper inventor property
  • Thread starter Thread starter Brethil
Brethil
hello to all;
I have a question to submit to you;
as well as in the assemblies it is possible to replace with the "replacement component" certain parts....I asked myself...in the tables *.idw it is possible to do the same in order to avoid having to redesign everything even if the tables differ little?
i.e. if I have a *.idw table of a metal base 3500x2100 which contains a file of listed and dissected together and I am having to make a similar table, but with another 3200x2100 size base, which differs from poc...can not replace the view of the previous base, maintain quotas and then save with name another file in order to avoid redesigning another identical table?
thanks in advance
with management > replace reference model in table environment you can do what you ask. because everything works well though it is better (necessary?) that your second frame has been done saving and changing the first, and not created ex-novo.
If I could make you a monument, you saved my c** or really!
Now I can save a lot of time, eh...
cmq seems that it is not necessary to have modified the frame on the basis of the original file, just replace and then change the odds that do not correspond.. 70% of work saved
Then if I have problems, I will know how to tell you.
I'm going to go
if it is a situation that often presents the road of iparts and iassemblies is certainly more functional.
Hi, I've heard of it several times, but sincerely I am arranging from ignorance about iparts and iassembly... I think I will have to find time to make me a culture and then I will know to tell you something.
Thank you
