painaz
hi, with onespace drafting/me10 when I use the command "parallel construction line" (c_line assistance parallel), I can both indicate the value of the distance and launch the command, move with the mouse and place the line.
when I move with the mouse appears the distance (which changes if I move with the pointer):
in solid designer instead, using the same command, does not appear the indication of quota. or the pitch "in the dark" or type the distance
Now, I'm sure to remember that drafting/me10 exists an environment variable or command to decide whether or not to show the "dynamic" indication of the distance. But I don't remember what it is anymore.
I would also like to see this indication appear in the solid modeling environment.
Any ideas?
Now, I'm sure to remember that drafting/me10 exists an environment variable or command to decide whether or not to show the "dynamic" indication of the distance. But I don't remember what it is anymore.I would also like to see this indication appear in the solid modeling environment.
Any ideas?
