batstar
Good morning to all,
I found a problem in inserting formulas into the parameters in inventor 2014: practically (to explain it simply), I should make a steel cube starting from the weight and what I did was create a user parameter where I insert the weight value and a "side" parameter with formula "(weight/7.85)^(1/3))", (where 7.85 is the specific weight of the steel), I find myself with result a x10 value! the same formula in excel gives correct result, I cannot explain why and at this point I wonder also about the correctness of inventor calculations.
Can anyone explain this error?
