parameter table
  • Thread starter Thread starter MaiMollare
MaiMollare
Good morning
I would like to put in a drawing table the coordinates I used to create a drilling on the model.
so that if they change again in the model I also update the table.
I have identified the expressions that interest me in the model but I can't take them to the table.
What is the syntax I have to follow. for example for the p90-x expression what do I write in the table cell?
Thank you very much
is the drawing inside the same file where you have the model or are separated?
if they are together you can try to proceed like this:
- create the table
- Right-click on the cell and select edit text
- expand the symbol section and from the drop down menu "category" choose relationships
- selections insert expression and choose the expression you need
if they are separated (you have the model loaded into the drawing file)
- follow the procedure before
- in insert expression click on link to part
- select the part where you have the expression you need
- choose the expression you need
Good job
perfect, that's exactly what I wanted to know, and you explained it very clearly, thank you very much
