parameters data field
  • Thread starter Thread starter Damvr
Damvr
Good morning to all
I have a problem in the drawing that I attach
I do not understand how the data field was created or set in the text at the bottom reported to the thickness 6/10, I do not understand how it is created the 6, I hope to have been clear.
Thank you as always.
It is a formula field, without any expression, once there was the calculation of the thickness.
without any indication of the thickness, getting that 6/10 I don't know how to do, it's not a matter of knowing the formula, just missing the data.
Sorry I'm late.
the data is on the ties window and changing the dim. l and h the development is calculated. data is in the parametric window
ok, edit the field with the value 6, in the formula pane click with the right button and enter the object field, select the thickness line and multiplies by 10
ok great, I had only in the formula window with the button dx insert an object field.
Thank you very much.
by curious I do not find in the regulation of the forum references to how to report the resolved conversation.. Can you tell me how to do it? ?
