stilo64
Hello everyone, excuse me, I use inventor for work and I think it can be faster but I don't understand what I could do to speed up the drawings I make.
I created a part with a parameter that with the module I fill my holes in a tube with different steps. Then I created a set that recalls from the tube that I parameterized together the connection of the data assigned to the tube that I created parameterized.
So when I go to the tube by assigning a number of holes and steps when I return to the axieme, I automatically change the size, since in the holes I lodged some logs.
in the table when placed the drawing recalls the distinct material.
the problem that if I had to do another together with different quantities I have to copy the tube then the axieme and then the table.
before opening the new set from the design assistant change the pipe connection so that they are parameterized together.
from the table setting by the command replace model reference put the name of the new set-
I think it's a bit windy, is there a faster system?
