Tarkus
Hello everyone,
different time ago, I was created of the ifeatures, the classic gorges for seeger, one for every seeger thickness, where the changeable parameters were the diameter and the distance from the plane; the other parameters (thickness and depth' throat) were always those, so I had not inserted them in the table.
Now I need to have features where I can change the other parameters.
So I thought I'd make copies and edit them.
But if I open the ifeature file directly and go to "modification feature" it makes me see only the parameters already 'changeable, in order to be able to see the others, I have to go to "dose creation", and here, under the processing node, it shows me, even I can't convert them into table parameters.
In fact, the guide says that:
< in a table based ifeature you can change the values but you cannot add or remove parameters or geometry. >.
Is it possible somehow bypassing the obstacle?
