parametric for construction of plate supports for laser
  • Thread starter Thread starter cliff23
cliff23
turning on youtube I came across this:
http://www.youtube.com/watch?v=iccdqwdmdnaas in my company we also deal with laser cutting I would like to understand if someone has any idea
on how to build the parametric product for the calculation of the supports that will support the particular
to be cut on a laser cutting machine 5 axes.
would be a great time saving.
seen no answer I tried to make a parametric product to build 5-axis laser cutting plate supports of generic imbutes.
the product (which I attach)View attachment PALLET_PARAMETRICO.rarView attachment PALLET_PARAMETRICO.rar consists of the following parts:
- parametric pallets
-imbuted
-section 1
-Section 2
-section 3
-Section 4
-base
The procedure is as follows:
-I replace the "imbuted" component with the part of the imbuted on which I want to build the support.
- by helping me with the predisposed constraints they place it correctly on the pallet.
- on the part "parametric pallets" there are parameters to correctly size the pallet (nr horizontal/vertical sections, base size...etc.etc.)
- lastly I replace the 4 surfaces published with the surface of the skin that I will have properly prepared on the imbuted part.
everything seems to work properly, try to play with the parameters of the "parametric pallet" part.
on the basis I also added the indication for the laser engraving of the three points for the orientation in the pallet machine itself.
are missing only the ink teeth between sections and base. but as they should be different between the various sections to avoid
I don't know how to treat them.
we accept suggestions and any other solutions
