parametric formula
  • Thread starter Thread starter cen82
cen82
Hello, everyone.
I need to automate, to change the length of the piece, the definition of the number of holes being known (I insert by hand) the pitch of the holes.
I'll explain better with the formula I use.
[numero fori] = [lunghezza]/ [passo fori]il problema sorge quando [numero fori] is not a whole number and in fact in inventor during the creation of the series of holes, in the holes field, of course, does not accept a number with decimals.
what I need to understand is if there is any kind of education that allows me to take only the whole part of the value [numero fori]for example in vb or excel doi:
int( [numero fori]help :-)
ps but there is a guide for the programming language accepted by default by inventor?
the default inventor language is the vba, and the network is full of tutorials and manuals. the problem is to interface to inventor to read and write parameters or do more complex actions... ilogic should greatly simplify life and f1 does wonders!
In your case, I wouldn't shake any of this. I would create a custom parameter in the parameters window and use the formula :
floor(100 mm / 30 mm) (=3, floor round bottom)
or
ceil(100 mm / 30 mm) (=4, floor round top)
of course instead of 100mm and 30mm other custom parameters or less, and the parameter you insert will have unit measuring "on", without unit: that parameter is then usable as you prefer
Bye!
Thank you so much! :-)
after your answer I found a list. Maybe it can help someone.
hello and thanks again
use of equations and parameters
you can use equations wherever you can enter a numerical value. e.g., you can write equations in the Edit Shares dialog box, parameters and features. equations can vary according to complexity and it is possible to use them to calculate the size of the processing, offsets or angles of the joint constraints or simulate the movement between multiple components.
equations can be simple or contain many algebraic operators, prefixes and functions. here is a simple equation as an example:
2 on *(6+3)
the following complex equation uses internal parameters, including the pi:
(pi rad/5 on +(25 gr * pi rad/180 gr))
algebra operators
the following table lists algebraic operators supported by autodesk inventor.
operator
meaning
Addition
subtraction
mobile comma module
multiplication
Division
power power
Delimitation of expressions
delimiter for functions with multiple topics
prefixes of units of measurement
the following table lists the prefixes of measuring units supported by autodesk inventor.
prefixed
symbol
value
Exit
and
1.0e18
peta
p
1.0e18
you will
1.0e18
giga
g
1.0e9
mega
m
1.0e6
Chilo
1.0e3
h
1.0e2
Decade
from
1.0e1
decisions
d
1.0e-1
cents
C
1.0e-2
m
1.0e-3
micro micro micro micro micro micro micro micro micro micro micro micro micro micro micro micro micro
1.0-6
dwarf
No
1.0-9
Pico
p
1.0e-12
fem
1.0-15
Act
a
1.0e-18
when using the measuring unit prefixes in an equation, enter the prefix symbol and not the prefix. For example, an equation that includes the measuring unit "nanometer" could be expressed as follows: 3.5 ul * 2.6 nm.
adding the prefix of the unit by name to the metric unit, the equation will be calculated according to the length of 2.6 nanometers.
note for the symbols of prefixes is made distinction between upper and lowercase letters. Enter them exactly as they appear in the previous table.
Functions
the following table lists the supported functions.
syntax
type returned unit
type of unit
what(expression)
without unit
angle
breast(expression)
without unit
angle
tan(expression)
without unit
angle
acos(expression)
angle
without unit
asin(expression)
angle
without unit
atan(expression)
angle
without unit
cosh(expression)
without unit
angle
tanh(expression)
without unit
angle
acosh(expression)
angle
without unit
asinh(expression)
angle
without unit
sqrt(expression)
Unit
any
sign(expression)
without unit
any (returns 0 if negative, 1 if positive. )
exp(expression)
without unit
any (returns the exponential power of the expression: for example, returns 2 for 100, 3 for 1000 and so on).
floor(expression)
without unit
without unit (minor next whole number. )
ceil(expression)
without unit
without unit (more next full number. )
round(expression)
without unit
without unit (closer whole number. )
abs(expression)
any
any
max(expression1;expression2)
any
any
min(expression1;expression2)
any
any
(expression)
without unit
without unit
log(expression)
without unit
without unit
pow(expression1;expression2)
Unit
any and without unit respectively
random(expression)
without unit
without unit
isolated(expression; unity; unity)
any
any
note for the names of the functions is made distinction between upper and lowercase letters. Enter them exactly as they appear in the previous table.
reserved system parameters
the following table lists reserved system parameters supported by autodesk inventor.
parameter
value
3.14159265358932384643383
and
2.7182818284045236
types of units
the type of unit used with an equation depends on the type of data you are considering. for example, to evaluate a linear or angular value, use the type of unit in millimeters, inches or degrees (mm, in or gr)
some equations must return a value without unity, for example, an equation to solve the number of occurrences in a model. is designated a value without unit with the characters on. for example, 5 on means that the equation has been evaluated and returned number 5, as in the number of occurrences within a model.
note maintain the uniformity of units within equations containing parameters that represent different types of units. this is possible using the island function. For example, to calculate the number of occurrences of a model based on a recurrence for each unit of the width parameter, the linear equation would be as follows:
isolated(width;mm;su)
the number of occurrences in a dialog box requires a result without unit (on) but you are referring to the width unit that corresponds to a linear value. convert the width parameter to a value without unit.
