part body with different materials
  • Thread starter Thread starter Sasso SP
Sasso SP
I have to simulate with the v5 analytical module a small structure with different materials.
to do the analysis I have to have all the body in one, here comes the problems,
the material imposed it when the body is still separated, once I go to do the addition of my body to the partbody automatically
acquire the partbody material.
how do you set different materials in a part body?
thanks for any answers.
View attachment 33353test with the procedure in figure.
thank you for the answer but it does not work,
in the actualmant sense thanks to your procedure now in a partbody I have more body with different materials but qunado
amount the file in the analysis module opens the window that warns me that no material has been set.
doing the test in the environment part setting the display on shading material does not make me see the surrender with the
color of the material, something different if I did it before adding.
I start thinking maybe I have to have a file for every detail that changes material. . ?
I continue here the discussion even if it changes genre, at most will be moderators to change the forum, in case thanks.
I am trying to simulate the various parts no longer as a single part but as a whole, my procedure was to make a
together with the 3 parts and bind them to each other, once imported into the analysis module I can not understand how it should do to bind
between them? but the constraints I set in the asmby do not recognize them? Do you need to use virtual parts? How?
