part derived from disconnect and import
  • Thread starter Thread starter enry79
enry79
Hello.
I am working simultaneously on creo and inventor.
the problem, I created a part working on a derivative part.
Now I would like to delete the connection to the derived part (it is like I know it), but the origin (we call it "gree"), remains as imported and it is not possible to make changes.
Now, when disconnecting into the creek, operations are imported into the part, in practice they place themselves in place of the link to the crude and list themselves in the model tree, as if you had done the part on site.
How can I in inventor, disconnect and import all operations in the child part?
the solution of creo seems very intelligent, but from what I find it is not possible in inventor.
to have a disconnected part with the whole working tree, you should start from a copy of the original part and work on that.
I understood correct from the English sites... but it seems like a real...... i.e. in practice converts the model into iges and then inserts it into the son part and then holds the bond in this way....
(In fact, unlike I create by modifying the origin, I must then do the regeneration... which in I create is not connected directly. ..
Thanks for the answer.
