part new coupling on the place
  • Thread starter Thread starter teseo
teseo
hello to all;
I have a problem to undergo;
I have a set in which I insert a part with the command "new part"; the latter will be created with references in the context and with coupling "on the place"; And so far it's okay.
now I want to replace a part of the axieme with the command "replace components", but the part I want to replace is linked with the coupling on the spot to the part inserted with the command "new part"; solid at this point after the replacement rightly finds no references to create a coupling on the spot and suspends the coupling on the spot.
the coupling on the place can not be reactivated obviously with new constraints? I did not succeed,, does not allow modification, does not allow forcing......other ideas
the replacement part must have in common the reference (plan, axis, edge...) of the coupling, so it must be a modified copy of the original. otherwise you change the coupling (which to me in a fast trial did not suspended, but gave me error) and select the new references.
you are right I have done it again and it gives me error but going on the coupling and selecting change function does not make me change a dry fig, it is exactly what I can not do, to insert the new references....
I retryed by giving the references of the sketch by remaking the references points and plans the sketch does not give me any more error but the coupling on the place does not go to place continues to give me error.if instead I click on the coupling on the place and change function tells me: See below. Do you know that once you lose the references you can't hook them anymore or am I wrong? ? ?
when I join two components tells me "to perform the selection of couplings from two different subaxis "
What does that mean?
without context and without knowing what you are trying to do you can not respond carefully, but only shoot random hypotheses.
your ability to write that you will create new discussions and then not do it is almost moving, at least are you sure to refer to solidworks and not to catia?
you are sure to refer to solidworks as I want to learn it; As I have already written in a previous message I can no longer create a new discussion (and I don't explain why) that is not private so, please, instead of reproaching me why you don't give me some tips so I learn?
button new discussion
Please, instead of reproaching me why don't you give me some advice so I learn?
because otherwise you will never learn and continue to repeat the error. If one is wrong, he corrects it.
that right you want me to give you if I have already written that the only information you put is not enough to give a correct answer.
hello to all;
the coupling on the spot is a boiata "just to do soon". I would avoid using it, rather it uses a origin on origin with axis alignment, at least it is manageable. use it only if you have to do something simple, fast and "use and throw".
