m_arquati
I'm wondering if there is (and I'm sure there is) a way to get a screw to make a hole (for itself) in a part where it is inserted into a set.
in my case: I do a part by extruding a rectangle; I do a part by extruding another rectangle (larger); I do a set in which I insert the two parts with the first part that competes in the second.
I would like the rectangle-shaped hole to be formed with the size of the first rectangle... in solid top you can create a parametric element of library.
I'm just as sure that you can!
the example is to make a hole for a door in the wall that welcomes it!
Thank you so much!
Mar
Thank you so much!
Mar
