part to multibody
  • Thread starter Thread starter Marckmarck
Marckmarck
Good morning, I find myself in this situation I created a part with various extrusions, erroneously I did not remove the flag on "unisci result", now I would like to in the table but to be able to make views of the individual extrusions, as if it were a multibody, that allows you to select the bodies in the table. There's a way to do it without remaking the whole part. I've already tried to remove the flag but now the various extrusions are tied.
I can't do anything with the command. Now using it tells me that it is not possible to create bodies from a flattened body.
I'm sorry I wrote it, "You're publishing the answer," but as I told you, it gives me that mistake, and it doesn't let me divide.
There should be no great difficulty in setting up those few functions (about ten or a little more) used to do that detail by removing the result unit. all functions are suspended, and one is activated by a cascading system.
Anyway, I don't see the difficulty in dividing the piece
the tondo divides it by cutting loops with internal diameate equal to the diameter of the shaft and thickness 0.0001
the same thing with the upns (which you did not with the structural members otherwise would not be joined to the rest of the body)
I wanted for example to have as a single body one of the arms, to make it the emssa at the table, but when for example select the two surfaces and I make size, it gives me the error "impossible to create bodies from body to flattened sato"
attach the step.
I wrote you a method, you could try that
I can't imagine what you're doing, forgive my little fantasy.
shows the feature manager at least to understand what surfaces you are talking about, what settings you used... and put a bigger picture
I didn't buy anything, but I won't charge it tomorrow if I can send you photos while I use the function.
a function divides only and work is done.
when you put the feature manager you can think over
but you managed to split the first arm, from profile to u, from 2 arm etc. When you select the contour you give him the face or the sketch of the contour?
