parts in iges that do not hide
  • Thread starter Thread starter principe7477
principe7477
Good morning to all
I have a problem, I can't fail to show some imported parts in iges or step into the axieme, creating the tables these parts are always underlined even if they should not be visible.
Does some of you have a solution?
thank you in those who will help me
we need more info:
- Did you hide components with levels?
- Did you make simple representations?
-Is the problem graphic or bom?
If you put a couple of pictures, you can give you extra directions.
I entered an image
those circled are imported parts in iges
should not be visible because they are behind other parts
because they are most likely sets of surfaces and not solids.
the surfaces create/pro-and treat them differently than the solids for the views.
if in the views with the levels the surfaces (surface) disappear (but even if there are no other solids in front), if you can solidify the models, the problem disappears completely.
