party
  • Thread starter Thread starter luca343
luca343
Good morning to all,
use by 2 months about inventor 2015 for work and being paired to use other programs for design, type top solid and solidworks, with inventor, even if they look a lot, there are some things that do not come back especially one in particular and I expose it with an example:
I create a set that I call "assieme_1" composed of real parts including an extruded profile that is the main component of the axieme; in a single file together place the 2 "assieme_1" bound in some ways between them....if I vary the length of the extruded profile of one of the 2 "assieme_1" I change the length also of the other being the 2 equal. what I would like to ask you is if you can tell me what is the command that "dissociates" the 2 profiles so that I can change the length of one without the other having the same change.
I hope I've explained well.
Thank you very much.
Luca r.
see if I have understood correctly; you have a .iam set that is composed of two other assemblies. within these two assemblies there is a repeated .ipt component 2 times. I don't think you have much chance, except to rename the component with another name. just a _1. Then go replace the component with _1. I suggest you replace everything. other thing; if you have already made the component's table, without having to remake the _1 (see that they are the same) I recommend you to do the rename of the .dwg, but to save it out of the folder where there are the other .iam or .ipt files that you need for this together. then cut and paste into the "right" folder the .dwg file. at this point the system does not find from what your .dwg is composed, so you have the option to select it ..._1. so you will find the browser with the two drawings.... and ..._1 with the correct links.
I hope I've been clear, otherwise ask.
Paolor
Thank you very much for your answer.
basically I can't create a single .ipt file, use it for multiple .iam files and vary the .ipt file in the individual .iam axiemi so that in the other axiemi the .ipt file remains unchanged; I have to create so many .ipt files as many variants as I have to create.
I thought you could do it.... .
....benefit to use other design programs, like top solids and solidworks, with inventor, even if they look a lot, there are some things that do not come back especially one in particular. . .
....in essence I can not create a single .ipt file, use it for multiple .iam files and vary the .ipt file in the individual .iam axioms so that in other assemblies the .ipt file remains unchanged; I have to create so many .ipt files as many variants as I have to create.
Bye!
a curiosity since I don't know these two programs: but with top solid and solidworks can you do it?
Yes, you can, you have to create an ipart.
in other terms is a part with some or all parameters under table, directly from the axieme you can vary the table and then in your case the length . All this does not go to affect other axiemes where you have already inserted the component.
to make your .ipt a ipart go on management/create/create ipart and do some tests...
ah well, as ipart ok, you can also do it with inventor, but if you have to make a table of the particular 1000 long and one 1500 long it is best to make two separate designs.
Yes, with solid tops, for example, when inserting the component makes you choose whether to keep it "winked" to the original or as a new component with a story to itself and then you can change it without changing the original.
with inventor I understood that it was necessary to use the ipart command but it is not yet clear how it works.
but if you choose to insert it as a new component, is this new one saved somewhere?
no, it does not create a new file, but only a component within the axieme
then generates a new component as if it were "temporaneous" within the axieme?
What if I lock that component away?
I share what Paolor1 says!
are two different components and managed as two distinct objects: then that you do it with a generic table, or with two "separated" files is a matter of choice, according to me.
of my original .ipt file I created the iparts at different lengths as I need, but then when I go to resume the .ipt file inside the axieme it does not make me choose the different lengths; in the browser appears the table entry with its options inside it but from the .iam file does not make me choose what I want, while in the .ipt file it makes me choose the options I entered creating the table.....how can I do? ? ?
together, in the browser:
- expand the knot of your ipart
- Right click on "Table"
-modification component
tab "table"
choose your length and give ok
tab "table"
If I do right-click on table the only items that come out of me are expand all levels, buy all levels and like....I don't have any other entries.
Don't I have to do something with ifeature?
bho, I don't.
If I open the table node I find:
- Done.
- magazine- originIf I click on "Table" I have these entries:
-Returns (last command)
-change component (the item we need to change the table)
- How. .
the voices you say come out by clicking on the knot "original".
sure to click on table?
bho, I don't.
- Done.
- How. .
