passage libraries aspects/ materials inv21 to inventor 2022
  • Thread starter Thread starter windreef
windreef
hello to all
is there the possibility to implement any new materials of 2022 libraries in the 2021 material library that I use and that I customized? In fact, more than one question is a point of reflection, in the end, the materials I use are the ones I have customized, probably nothing.
when installing inventor 2022 you just have to tell the software to go look for: Project file, content center, template and folder "material design" from the same directory as inventor 2021.
going forward with the version you do not have to make any conversions.
(what you can't do is go back... instead).
Yes I did so, but I was always wondering using the same library , I use it since 2019 , you lose any materials and/or colors implemented in the later versions. The question of my post was that.
