TECNOMODEL Guest Mar 17, 2015 #1 in inventor can you set so that the file name displayed on the bar is complete with the whole path? Thank you.
Cast16 Guest Mar 18, 2015 #3 It doesn't seem possible. . . see: http://forums.autodesk.com/t5/inven...paths-in-inventor-program-window/td-p/3644686
Polymar Guest Mar 28, 2015 #4 you made a great observation, see the full path of the active file on the bar would be very comfortable, instead of resorting continuously to the iprop ... patience! :
