patran 2007 with view
  • Thread starter Thread starter armini
armini
hello to all
I am looking for the thesis to work with "patran 2007" but as it is installed on a car having "view" (:angry: ) I have problems with the various selections of files.
ie if for example I try to open a database the window looks all gray with therefore great difficulty to select the various files, and this also happens on other windows.
I found some kind of upgrade on the net, but I don't know if that solves the problem.
http://www.microsoft.com/windows/co...s&sc=industry-specific applications&os=32-bitor is it simply some conflict with sight and just wield some settling?
thanks to the attention
for what I know only patran 2008 is compatible with view.
for which or install the patch or upgradi towards 2008
wave
Hello, Armani.
2008 supports view, I do not think that with a view patch you solve the problem of 2007 that does not support view.
Please, thank you for the answers.
I had initially solved the problem by installing patran 2008 on view, but as for enchantment from one day to another it doesn't work anymore, or better when I go to launch the program begins initialization and then disappears like by magic without providing any kind of error.
on the installation documentation there is exactly this type of error:
"patran comes up briefly, then disappears with no messages"
only that as a solution they say only
"delete the key: hkey_current_user\software\msc.software\patran"
deleting all the pathran registry folder the problem persists, I tried to make a "recover system configuration" since it worked but nothing, I read on the network that the problem can be given by the video drivers ( strange because to me one day it worked and the next day not having installed anything) but I have the latest drivers available.
I don't know how to go on....otherwise I have to find a replacement software that can display the output files of nastran.
thanks again for the attention
I can't help you.
I know companies that have installed 2008 with view and have no problem. I've never heard of your problem.
However, op2 can be read with hypermesh and femap.
try uninstalling patran, delete registry keys and reinstall.
wave
Do a test... unsatisfactory aero view and test patran.. .
often, if the program is not compact with view, it is only for the new model driver that translates to 99% with an incompatibility with aero. .
bio
It is not a problem of aero, also because at first everything worked and I managed to work with about twenty sessions.
I went to read the files of Patran2008r1 sessions. the day he was doing correctly:
$# session file patran.ses.15 started recording at xxxxxxxxxxxxxxxxxxxxxxx
$# build: 16.0.028 sun jun 15 15:50:12 pdt 2008
$# recorded by: patran 2008r1
$# flexlm initialization complete. acquired licenses(s). .
$# licensed files: c:\msc.software\msc.licensing\10.8.6\license.dat
$# patran 2008r1 has obtained 1 licensed from flexlm for a
$# request to execute.... .
while only the next day without making any changes to the pc reported
$# session file patran.ses.16 started recording at xxxxxxxxxxxxxxxxxxxxxxx
$# the license for patran uses an older format that is no longer valid.
$# you must obtain a new license file from your msc representative.
$# checkout request rejected by vendor-defined checkout filter.
$# feature: patran
$# licensed path: c:\msc.software\msc.licensing\10.8.6\license.dat;
$# flexnet licensing error:-53,234
$# for further information, refer to the flexnet licensing end user guide,
$# available at "www.macrovision.com".
$# session file patran.ses.16 stopped recording at xxxxxxxxxxxxxxxxxxxxxxx
I don't understand what's changed and what he doesn't like.
arms
I had to renew my nastran license because it was in a "old format" and expired on September 16. I had appeared an error message in the f06 of the run nastran and had to request a new license file to the msc. You probably should do the same thing.
wave
this story of September 16 I did not know it, in fact then at the end last night as last beach I retrodatato the pc to September 1 and it worked magically.
I will now request a new licence :-)
thanks to all of the answers.
soon
arms
Hello I am a graduate of aerospace ing., I used for the paran thesis 2008 that as by magic all of a sudden it stopped working...I need qsdt program for company specifications ... give me a help to solve the problem... Can someone give me the general picture of the situation and how to solve it?.? please in October I have to graduate and I have the *.db already saved in patran 2008... helpoooooooo thank you in advance for availability... Angel
You need to contact msc and get a new license file. It's the only system.
in the meantime that you get the new file you can put the date of the pc before September 16. Then you have to stop the license server, restart it and reread the license.
attention that modifying the system date normally creates a lot of problems to the pc. so do it only in case of need and as long as the msc does not send the new license file.
wave
wave
I'm sorry to thank you for the answer, but if the license comes in time from the msc?? or nn I could have it.. what can I do besides the set of the date? and if qst is the only solution you tell me how I can do it..? a last thing, do you think I would solve the problem with the release 2 of patran 2008?? Sorry for tt qst questions but I'm almost desperate...:frown::eek:
If you paid for the program. the msc should give you the solution in 7 - 10 days to me so much you put it.
If you have it, see it yourself.
wave
wave
No, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no. Thanks again nn know how...:finger:
