pattern su curva
  • Thread starter Thread starter dema
dema
I'm not sure what version is present but from wf4 you can make a pattern that follows a curve and to work it needs only two things:
  • indicate a curve
  • the step or number of repetitions
well only that I have a problem the object does not follow the curve as it should as you see from the enclosed jpg the series of drawers is moved compared to the sketch, this is a problem but on which I could survive.
the biggest problem is that the first compost is at the top of the curve but when turning the orientation remains right is that the component is no longer outside the curve as it should but internal. as attached chain drawers here dani-3d went close but the stitches in the curve once are internal and once they are external.
If it can be useful to you, I draw them like this.
in the described parameter there are both description and length.
This defect often occurs when a sketch is taken as a reference to the series, try to bring the curve to the series, should improve.
I tried to unleash the curve, but nothing changed, in my opinion it is wrong because that particular called drawer must follow the shape of the chain so I think it is right that the sketch is in the chain.
try to bring the diameter of the series to 220.
Unfortunately you have to adapt the sketch quotas until you reach the desired development.
It doesn't exist, this is a sin of the program, I will continue to use the old method of point pattern.
open the 611fe106001_ic13879.asm.1
You are perfectly right, it is a big kiss of the series that in the past has created me not a few problems, partly solved by circumventing the problem.
