pattern through relationships
  • Thread starter Thread starter marco82sp
marco82sp
I'm trying to create a pattern to betray the inclusion of a relationship. being the first time I happen to do so, I would like to know if there is a discussion (I have tried but I am not entirely satisfied) or a tutorial where the syntax of relationships is explained (for dummies, preferably:
in a few words, I have three holes arranged on the same reference circumference; referring to the first hole, the second is at 90° and the third is at 225°.
Thank you!
you can use the report series but in this case I would recommend the set points or the table series.
Bye.
it is better to create the series by axis,
and then edit it again, and change it "by table"
and inserts in the table the 3 values of the corners
Hi, I have a similar problem I can't solve.
I would like to command the number of repeats of a series (axial) through a parameter. Specifically, I made a parametric wheel and the parameter in question is the number of teeth. pro-engineer gives me error when I enter the parameter name in the menu that requires the number of repetitions as it expects a real value (and not the parameter name). the limitation is not bad because, in any case, before regenerating I go to change the parameter by reminding me then to go to manually insert the number of repetitions in the series. If I could fix it would be the last step of parameterization. thanks and greetings to all.
