pattern view printing
  • Thread starter Thread starter Zandry
Zandry
Good morning to all,
First of all I introduce myself, I am going and I make the designer of electrical installations.
I often use autocads for tables and patterns and with the latter sometimes I have to print many sheets...I come to the point.
I have some schematic files that contain many pages designed on the model, to which I assigned views for printing convenience. Is there a way to automatically print all the views one after the other? without having to do every time print -> and change the display. I print it on pdf file.
use autocad 2012 64bit on win seven professional 64bit system.
I thank you for the answer, but I tried it and it does not work and then reading on the forum of the link seems to me a script to print all the layouts, I need to print all the views. Maybe I got it wrong. when I start the script gives me the following error "plotviews.lsp loaded. command: ; error: excess right brackets in input". reading on the forum I have seen that there is also some parameters in the scribe but I have no idea where they should be inserted.
Thank you for your concern.
