pattern with variable quota
  • Thread starter Thread starter max061271
max061271
Good morning, everyone. I use sw 2017 and it seems to me to remember that you can change the step of the pattern for each variant... is it correct?
thanks for the answer but did not activate the check box of instances to vary because the function was made with bodies instead of with features and faces.
I solved by doing with the latter even though with bodies it would be better.
if you have to use the cups, do a repetition guided by the sketch that according to me, at the cost of a little more time, is more efficient and easily manageable
