pdf export line thickness on inventor 2016
  • Thread starter Thread starter riccardo.toscani
riccardo.toscani
Good morning I have this problem with inventor 2016:
exporting a table in pdf the lines of the axes and in general the dotted lines and that should be lighter are on the contrary thicker. View attachment prova pdf.pdfAny suggestions?
thank you rich
the question is of the line style of the section lines.
you can change the thickness from the management of styles (but you can also tap on the ends) or click right on the section line and from the menu choose "hide axis line" and then create the axis with the appropriate commands.
thanks ilario I preferred to change the styles.
to the next
