pdf file names truncated by default
jim78b
because when I take it through adobe in pdf I am proposed the name of the file identical to the name of the dwg but sometimes it cuts it as he wants, that is not put all the name of the file such and which to the dwg.
example:
pj120_17-00001_00 f.round ø6500 (2 sheets) folded invert.dwg
pdf file: pj120_17-00001_00 f.pdf
Why?
to see your example, adobe seeks the point to eliminate the extension, finds it but it is the wrong one and also eliminates what should not.
If you want to avoid this defect, replace another character at the point, obviously not the final one before the extension.
bye
