pdf printing problems in autocad
  • Thread starter Thread starter Andrea.Zep
Andrea.Zep
hello to all, I have a problem when molding with virtual autocad printer; my dwg owns an attached pdf and at the time when I go to print in pdf almost all the pdf file has like a kind of noise and the writings are not sharp but have a contour. I tried changing the resolution but the problem persists. I attach an explanatory image of the problem where we notice both the text in the exported pdf and the pdf image where this strange effect is present.
the procedure used is as follows:
- autocad print pdf (high quality print);
- maximum quality 200 dpi
- result: image below.
I think it's normal. probably it is a scan and already in the scan there are these imperfections. in any case the writing will always be "pixelata" as the pdf is treated as an image.
I noticed that if I use another software (draftsight) I have no problem with the same file. I also happened on other machines with same file. if instead of the pdf attached, I use a jpg file I have no problem.
then use the jpg... that the pdf in autocad, even if possible, is of a unique lens.
saves pdf as jpg and attach it as an external image
from what you see to video, pdf seems to me a raster scan (gray pixelated windows)
seems to me a raster scan too. alternatively try to change virtual printer in autocad.
