pdm enterpise export data to management
  • Thread starter Thread starter joyjoy
joyjoy
Good morning to all,
as I am here to ask you what is possible to export from the pdm?
I clarify better, I have a problem with the multi-body files of solidworks2012 that the pdm fails to see, that is every component (piatto,tubo,lamiera,ecc.) has its own raw material code, code that I need to order the material.
how do you manage the first tides?
I recommend that you leave the design with welded... ?
Another problem is the export of the size (height, width and thickness), now I seem to understand that if I have a sheet file (i.e. I use the sheet functions to create a simple unfolded dish) these data are exported to me, but if I use an extrusion (to save memory/optimize the opening of the file) I have to write them by hand. .
I thank in advance all those who will want to tell me their experience about it
Good day:
I don't know pdmwe well, but I know this is feasible. ready2works does it at two levels:
the first creates a table for the unloading of the warehouse for the management, available in the vers. base
per second manages the multibody as a real asm and this is only in the vers. premium premium
now that by default pdmwe do not do it can be, but I think with some day of implementation can communicate quietly. I can tell you a person who can put his hands on it, but I'm not here to advertise, first you feel your dealer and then if you don't jump out I'll give you the contact.
thanks re_solidworks,
I try to hear the dealer and let you know.
If there is any user using pdmwe I would like to know his experiences.
thanks again and good work
epdm has always exported to the outside a xml file containing the information of the distinct. However, these differences are incomplete (not exported :mad:) with regard to cutting, welded and part-part parts. The only way is to go and read directly on the db. information such as size must be "map" on its variables.
Say hi!
