Cat_min
Good morning, everyone.
use solidworks (sw) with the ready2works management (r2w).
these two programs interact well but I would like to understand if you can do the following things:
1) materials. the material should be associated (2 times) to the part through and in r2w environment, instead I would prefer to attribute the material in sw environment and that it was r2w to read it automatically. You know how to do it?
2)assiemi-parti. r2w environment, if I have a set consisting of other subaxis and parts, it is possible to select the "father" axieme and that new codes are created for all "sons"? if we have a complex set consisting of hundreds of "children" to create for each one a code is particularly honorable in terms of time and it is easy to forget about the elements.
3)bom.
-every time you list the materials in excel bisgona uncheck the fields you do not need (e.g. "creatoil", "creatoda" etc.) and every time the program loses the settings. Is there a way to get r2w to keep the fields I need for the bom?
- is it possible to extract in one time the list of materials and pipes without having to go to the folder "type" to extract the excel files of pipes?
Thank you for your attention.
3)bom.
