percentage slope roof
  • Thread starter Thread starter CAROLINA
CAROLINA
Sorry
but I do not remember how the slope is quoted as a percentage of the slopes of the roof in section.
thank you and a thousand... .
> share > inclination at a point
if the quota does not propose the percentage value go to "type change" and in unit format entered as "percentage" measurement unit
this implies creating a new type of quota and Unit format Enter as a measuring unit "%".....right.
otherwise the change (percentage) would affect all the quotas already present!
I want clarification.
meanwhile we are talking about a quota "angular" (it is correct ?) that by default is already set for angles in degrees.
if you want the angle not in degrees but in percentages, using the procedure described: <"modification type" and in unit format entered as "percentage" measurement unit > option % non si rinviene.
I am using revit 2014
Exactly, I don't see what you see, the window has different content.
I created a layer and I listed the corner with "angular" quota and in "modification type" in unit format there is no "percent". as from image
How come? ?
hopsss did not understand a h
I didn't understand why I had never used the '' tilt in one place' command from now on.
My fault!!!!
