perform cutting using a surface
  • Thread starter Thread starter Rinko
Rinko
good day, I've been using powershape 2016 recently and I would like to know if you can cut a face of a solid using a surface. If so, how can I do that?
Of course that you can,just that the surface is unique and a little larger than the solid to be cut,to know which part of the solid will be cut looks at the surface, from the red side the solid will disappear,(if you want to remove it) or at the limit you can simply divide it, keeping the 2 parts of the solid; if you do not see the 2 colors of the surface click in an empty area of the screen with the right mouse button and click on : "Internal material"
