perimeter walls
  • Thread starter Thread starter Mone89
Mone89
hello to everything, I wanted to know how I can make 20cm wide walls that follow the course of the soil. It is a road and a plot with different quotas. Can you make it? thanks to all
if you mean automatic, no, i.e.:
1 - to use the default walls, you must first define the tilted plane (parallel to the ground) as host, at later times ...
2 - or, always with default walls, make walls (always at times) of "high" greater and then change the profile ...
3 - or make an in-place wall with an extrusion on path ....
in the forum, there are other discussions on the topic
Unfortunately the plan I use is a topographic surface, or in some cases a floor with the modified quotas, so I can not even use a host. doing so in place means putting too much time because it is a long wall and the odds change often and irregularly.
