MassiVonWeizen
I give you a very basic explanation:This thing about the folds is a beautiful bitch and I have to understand it well. Does the program based on the chosen material have a minimum calculation in this regard?
as I wrote those to calculate for deformation, I explain to follow are not unique values, but depend on tati factors and each workshop has its own that derive from sampling
when bending a sheet you have a structure deformation and a return or elastic release of the fold.
in practice if I design a sheet folded at 90° in reality, for elasticity of the material, once the press has created the angle you have a spring effect that opens or closes the angle (of a few tenths of degree)
when bending the material undergoes tensions that deform it i.e. alter its size; For example, a 90° l whose sides are 100mm can bend a 1mm shrinkage, which means that in drawing the flat sheet to be cut I will have to make it longer than 1mm, then 101mm, so that then bending it has as final result 100mm.
to come to your question if the software allows you to calculate these values; the answer is no because they are data made ad hoc by every specialized workshop. if you contact a workshop and give you the pick-up values then you can insert them into the parameters of the sheet creation to get the development.
as told to you interest the final result, as the previous example that the 100mm per side because it is what you use to build the houses; if you give the final file to the workshop will be this to calculate the flat geometry to be cut so as to ensure the final result
