photoview 360 e materiali sw
  • Thread starter Thread starter Loutenr1
Loutenr1
Hello, everyone. I happen, after applying for benign all materials for each part/face/body etc in sw, to open the axieme in photoview 360 to render. Now, not all the materials there are, some return to the plastic aspect by default :mad:
but shouldn't the two programs dialogue well? ?
are all updated at the same service pack? I don't know if they are made to dialogue so well, sure if you use photoworks the materials you recover them all, with photoview I'm not sure.
But with the renderings I am a hatch.
I'm sorry if I only answer now... Yes, same version for everything. Perhaps it may be that in some parts I forgot to put the right material, but the white that comes gray just don't understand
white can come even black if it is not correctly illuminated... to adjust all the graphical parameters of the parts are "transported" within photoview 360.. but not in "real-time."
These are two programs that are related, but independent, the changes made on a file in solidworks environment are updated in photoview 360 only after manual download/loading of files
from the photo you have attached however you notice that the part you have highlighted actually seems to take the parameters of the body surrounding it. .
how is it loaded within the program? Like together? sub-assiemi? single parts?
also.. did you do "material" operations directly from photoview? (e.g. dragging icons into the viewport - which in my opinion is a "confused" operation)
single part, and to the small cylinder inside I give the appearance by selecting "body". Anyway, like another user said, it's just white. If they select yellow you see yellow. all this working in sw
