& pie tubes - customization
  • Thread starter Thread starter IN.TEC
IN.TEC
Good morning, everyone.
I am here to ask you how to customize the inventor tube & pipe module libraries.
the need I have is to be able to create ducts, and relative curves and section changes, customized according to the standard I use.
in particular the ducts have custom thicknesses and diameters because they are for fumes treatment plants of steelworks.
therefore the thicknesses are different depending on the diameters of the pipes used, start from 250mm and can reach up to 6m of diameter.
Is there a chance?
to specify also that this module would only use it to realize the layouts, then the construction details would be made part by side.
thanks for the support
Faithful
p.s.
If you tell me that this road is not feasible in inventor, I ask you to suggest to me also what programs are suitable for this type of activity.
Like revit?
Thanks again
