piece of twist
  • Thread starter Thread starter LucaOt
LucaOt
hello to everyone, I'm struggling with a particular easy invoice but I don't know how to model in solidworks because I've never happened. Can someone direct me?20201002_081551.webp
3 curves drive them with 2d sketch while the fourth you will have to do it with 3d sketch.
doing as you say, wouldn't you have the same thickness along the whole piece?
Of course.
if it did not have the same thickness would imply a processing and not a simple twist.
where do you read that does not have the same thickness?
You're right, my mistake. Thank you very much, you have been very helpful as usual
I don't know why but I have the impression that if I took a thread and twisted it and folded it, I wouldn't get this visually. maybe doing everything in one loft?
I hoped utopianly that I would post the annex, otherwise what does it compare?
I don't have the complete design, but it doesn't look like a single piece to me.
Also the 3d sketch curve did not make it with a spline, but with a simple curve
The complete design is what I posted. I only have this. However, I imagined that in the workshop they took a thread and simply twisted it and folded it like that. I tried the "flee" function and does something that is similar to what I had in mind but you can't do it like that. I'll try
