Staedtlerp
Hello to all:smile:
I beg to be a neophyte and to have begun to use ansys only for a few weeks. .
cmq I come to the therefore...I have realized a piezoelectric travetta, I have assigned the type (plane223, therefore two-dimensional), boundary conditions and loads...my problem is that I can not trace the circuit connected to the piezo, and in particular I can not find the command that allows me to trace the wire, that is the piece of wire that connects for example a resistor with a capacitor. I press that I'm working with ansyss apdl with the command list, so I created a .txt file where I write my commands!
the strange thing is that while with the circuit builder (piezoelectric) I can easily track the wire with the omologist command, from the command list I don't know what command to use!
These days I tried to do one thing....I tracked with the circuit builder wire, and then, from the file menu, I used the write db log file command, so as to save the command list. the command list contained the wire commands that are the following:
et,1,200,0,0,0
type,1
e,1,2
cp,1,volt,1,2
cpmerg,volt
2 questions arise:
1) in the et command there is immediately after 1 representing the number assigned to the element, followed by 200 that should be the type of element....but in the guide and in particular in the element reference guide nn I find no element with this name...and then what are the successive numbers?? Boh!
2)When I copy these commands on my .txt file and put them in the command window, I track the wire, but differently than how the circuit builder does.. .that is: from command list the cable is represented with an arrow that goes from the first to the second knot, and on the knots there is a sort of circle. all this with the circuit builder does not happen, the wire is defined in a simple way as a connection between two knots, without arrows and circles....
I'm sorry if I've longed, but I wanted to explain things well:
Thank you so much!
et,1,200,0,0,0
type,1
e,1,2
cp,1,volt,1,2
cpmerg,volt
2 questions arise:
Thank you so much!
