meccanicamg
I agree. You've come to the static solution now. then admissible pressure and refractive sheet.Meanwhile I attach the diagrams related to the support.
I hypothesized the internal constraint pin+ghiere as a bond that prevents x, y, z and rotations from y, z axes.
fx, fy, rcx, rcy values derive from the free body diagram for the whole system.
Do you agree with the setting?
the rest the place tomorrow (the eyelids see me hour)
then do that dynamic and finish everything do two fems (static and dynamic) putting forces on the right areas and verify how much calculated. compare, report and present.
then if you want to parameterize everything according to the angle and you will have the values in all positions.
