CiccioDri
Hello everyone, today I am working on a project of a reference tree to be completed in order to carry out an examination of the university, so notice that I am to my first project and I do not have the least experience in this matter. I have completed the sizing of the shaft and all the components, but the problem is now finding a way to fix the pinion axially (which is radially pushed by a stick). the pinion is placed symmetrically between two bearings, which are fixed thanks to a shouldering (shaft diameter on the 90mm pin, on the bearings 70mm). the bearings are distant from the "walls" of the pinion 43,25mm. There are no axial loads and I would like to avoid adding additional carvings to the piece. Can the use of two metal rings placed between the bearings and the wheel be feasible? thanks in advance for the attention
