planetary assembly
  • Thread starter Thread starter p3time18
p3time18
Hello I have to assemble the various dense wheels of a planetary (crown, solar, 3 satellites) can you tell me how to do it?
it would take a course, not 4 instructions,
Anyway:
open a new product (environment assembly)
insert the main component
the fixed (symbol anchor)
insert the second component and constraints (with coaxial bond, offset, parallelism, angle etc., what you need)
same for other components.
when selecting a constraint, then in succession you have to select the geometry of the first component then that of the second one and change the various parameters (values, orientation etc.)
Thank you very much:)
I wanted to know if the ties between the axes are enough or if it is necessary to impose constraints on the tooth of the various wheels.
- - - updated - - - -
Anyway:
the planetary that carries the pins will have to be the fixed part, while crown, satellites and sun you will have to place them and bind them by axes (the pins and the central hole of the gears).
also put a offset distance to place the gears in height. make a fine adjustment of gear rotation to eliminate interference (by manipulator).
if you need to simulate rotation, in the kinematics environment you will have to assign the various parameters (dened joint/route etc.)
I don't know kinematics, but with some tutorials on the web you should get away with it.
Let me know.
years ago
Let me know.
years ago
Thanks a thousand years, now I try and keep you updated:)
Palo
