stefanobruno
They are looking for a semi-finished (round or slabs does not matter) in plastic material but with characteristics of electrical conductivity such as to allow a maintenance of grounding.
I tried with google but with the keys "plastic + conductor " only the silicone presenters come out:biggrin: (try to believe ).
I will try again with other keys but, in the meantime, I also ask the forum the question, you know.
they ask me to make reference points for the webb holes (body shop) with the surface of support in plastic material, in order to avoid noises, sin that so doing you isolate the shell from the rest of the equipment.
the grounding pantographs, which are born to solve these problems, do not want them.
Moreover the quantity is reduced (type 52 disks of diam. 60/80 sp. 10/30 mm) so I cannot hope for the interest of some supplier.
Thank you and hello.
