plastic molding regulations.
  • Thread starter Thread starter sbiru88rn
sbiru88rn
Good evening to all,
I have been following your discussions with interest for several years, but until now I have never participated. are a plastic design neophyte and I would like to ask you a couple of questions about tolerances in injection molded artifacts in pc:
- are there regulations defining the conditions (environmental, piece or instrument) to which the manufacture must be measured to verify its tolerances (between producer and contractor)?
- with regard to the minimum tolerances which may be required, it is necessary to refer to the regulations (e.g. 16901 or nf t 58000) or to descend even below the standard values?
Meanwhile, trusting in your experience, I thank you for your availability.
you must follow the indications that the customer gives you.
What is written on the drawing.
depends on who the customer is.
There are those who give you the champion and say "fallo like this."
there are those who have internal capitulates on how to do tests, tests, internal regulations etc...
