plugin renamebody
until a new version is released, that plug-in does not work.
meanwhile, you can add the ilogic script attached to your part and sheet templates.
when you need to rename the bodies, simply do it.
Unlike the plug-in you mentioned, this script also works in the "lamiera" environment.
the plug-in was only working in the "part" environment.
must (the software house) release a version of the updated plug-in that is really compatible with inventor 2021/2022.
the version currently available, for what I checked, works until the 2020 version (of inventor).
I see it from the pannllo of the modules added, but it does not remain the tick on loaded, and in the ribbons I do not see the command obviously1640071432550.webp
here you can find an alternative solution:
