plugin terreno
  • Thread starter Thread starter Marcusbox
that I know do not exist plugins (maybe I am denied!). personally I have always found myself strange with the module present by default in revit, both with regard to the creation of the ground through points of altitude and regarding the realization of roads (also uphill!).
on many occasions I would have appreciated the possibility of drawing a contour to delimite an area. I don't understand why they don't allow it.
when you need a very precise perimeter it is necessary to insert many points and it is not practical.
I usually start to realize a plot from the aerophotogrammetric, so I'm comfortable playing the ground through the points of altitude. If I have to make a very precise area, first I draw the lines that delimit it and then I model the soil;)
Why isn't it your job? revit is not an environmental engineering software where you work massively with soils, slopes, hydrographic basins!
